RE: Receiver range vs battery voltage
should be no difference the transmitter is doing the sending rx just picks up the signal when it reches the antena,that is why in the old days you flew with the tx pointed directly at the airplane as that was the weakest signal from the tx.if the plane was out of range you could turn the tx mitter and the stronger signal emmitting from the sides would allow you to regain control and fly back in range.
