RE: MY KADET LT-40 BUILD
There doesn't appear to be much selection in the paint department. If you can't use what you see I suggest that you glue the tri-stock in place and then cover the plane. It really should not be too hard. Do the seams (including the tristock area) and then do the flat areas.
Flying wires are not hard either, just something else to learn.
OK on the servo, as long as you can get the lead in/out OK.
