RE: TORO HI TECH TERD NEED EXPERT HELP
THIS IS MY FIRST TORO SO I HAVE NOTHING TO COMPARE IT TO EXCEPT WHAT IVE READ THAT ALL YOU GUYS ARE GETING FROM YOUR TORO'S. RING END GAP IS GOOD. TRANSFERRES ARE STILL STOCK AND I DIDNT CHANGE THE BOTTOM OF THE TRANSFER OPENINGS. THATS A GOOD POINT! TRANSFERES SHOULD BE IN THE MID 60 DEGREE MARK?? ARE YOU SAYING THAT THE BOTTOM OF THE TRANSFERES ARE SHIELDED BY THE PISTON SKIRTS? DO YOU MAKE THE TRANSFERS ANY WIDER OR DEEPER OR JUST HIGHER?
FARMER TED
