Going back to your original post mikmaxx, covering can be a little tricky the first time but a learnable process. Start off by viewing the videos that RCKen suggested and then practice on some scraps a little bit. Figure out what temperatures you want your irons set for and then just do it. Remember, this is a time consuming part of a build so don't be disappointed if it takes a while. Just take your time and think out each step carefully. Measure, cut, install, shrink, etc. Before you know it, you will be done.
