RCU Forums - View Single Post - new to tanks (different use)
Old 10-28-2005 | 03:02 PM
RRR
My Feedback: (30)
Default RE: new to tanks (different use)
ORIGINAL: heavyaslead
Is that 55t Lathe motor a direct replacement for a 540? Same size etc?
Do you have specs on the motor?
Cheers
Eric Scott
Yes it is!!! It is a 540 size motor.It Integy 55t singel lathe/brusher(ajustable timing & rebuiltable) cutter motor thay run about 1200 RPM per volt with loads of torque.I run a 4c pack in my KT and get 26 scale MPH and anuff power to climb a steep an angle as ANY gear reductshion unite thay make BAR none.I can take pix if yopu want some.
