RCU Forums - View Single Post - Need help with Evolution .61 tuning...
Old 10-28-2005 | 03:14 PM
mwarren400
Default RE: Need help with Evolution .61 tuning...
Make sure the muffler is tight (both the muffler halves and the engine screwss)...I had a similar problem with mine. You may even want to swap out the gasket and re-tighten...voila...no more issues.
This is a rather important thing to fix...when you are landing (idling for 5+ seconds) and get a bit of wind or a big bounce ...you need the smooth throttle transition to avoid pancaking it. Nothing worse than having the engine quit after you got the nose up with too little airspeed.
