Nickolas...I'm using the YS110 with HiTec metal gear servos. I put my rudder servo in the fuse with the pull/pull. Mine balances right at the recommended CG with the 4.8 battery just slightly forward of the CG. I'm using a mini servo for the throttle and have the tank on the CG so this helps keep the weight back.
All I can say is mine would have been tail heavy with the rudder servo in the tail.
Barry
