RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-29-2005 | 08:19 AM
  #1147
bdavison
Default RE: E-FLIGHT BLADE CP
OK guys,
Here it is the 9C programming.
Well, here's what I got
First set it for PPM. NOT PCM
Pick swashplate type SR-3
Goto SWASH AFR
make ailerons -50%
make elevator +58%
make pitch +64%
Goto END POINTS
make throttle 43/100
Goto REVERSE
reverse the ailerons, and the throttle
Goto PIT-CV/NOR
Point 1 46.0%
Point 2 52.5%
Point 3 57.5%
Point 4 63.5%
Point 5 75.0%
Goto TH-CV/NOR
Point 1 0%
Point 2 25.0%
Point 3 50.0%
Point 4 75.0%
Point 5 100.0%
Goto REVO./NOR
Mix = ON
Point 1 -20%
Point 2 -10%
Point 3 0%
Point 4 +10%
Point 5 +20%
Goto the advanced menu
Goto HOV-THR
MIX = ON
Turn the VR(c) knob till it reads
RATE=0% (-71%)
Goto HOV-PIT
MIX = ON
Turn the VR(a) knob till it reads
RATE = 0% (+10%)
This is just the set-ups for normal mode.
You ABSOLUTLY MUST VERIFY all the settings on your helicopter BEFORE you attempt to fly it. I dont know if this programming will work for every Blade helicopter, but it should give you a place to start. Most likely you will have to make fine adjustments to the Pitch curve to get the correct one depending on where your servos are centered and how the linkages are tuned.
Ill say it again. YOU MUST VERIFY THAT THE BLADES ARE MOVING CORRECTLY AND ALL DIRECTIONAL LINKAGES ARE CORRECT B E F O R E FLYING IT!!!!
If you dont know much about this, I wouldnt recommend trying it until you can have someone that knows about helicopters verify that your heli is set up correctly.
