RE: TORO HI TECH TERD NEED EXPERT HELP
Hi Teddy,
Once you get the engine to run cosistantly, you can run it with a smaller prop and if the rpm doesn't go up you are rev limited. Make sense? You don't even need an accurate tach since you are comparing numbers from the same tach.
Dave
