RE: E-FLIGHT BLADE CP
Bdavison:
I did not follow your advice and am attempting to program my 9C. I think I have it set up to your specifications correctly, but I can not get the 4 in 1 to initialize. I did notice that you had two entries for the TH-CV/ NOR and none for the pitch. I tried it both ways and had the same results. I also tried the throttle end point both ways to make sure I had entered that correctly. I also put the throttle trim all the way down but with the same results. Any suggestions?
