i have a zenoah 40 cc gasser with walbro carb. i get the engine started easily with a squirt of gas in the carb. the problem is keeping it running. doesnt seem to be sucking gas up to the carb. any suggestions on hot to fix this or something else i should be looking at. it will run for 5-6 seconds then cut off.. i assume this is due to the lack of gas. if i need to clean the carb out what should i use and what do i take apart.. any suggestions would be appreciated..
thanks
