RCU Forums - View Single Post - BUILDING your own VPP Setup
Old 10-30-2005 | 10:22 AM
  #42
Planelover_CrAzY_Murdock
Default RE: BUILDING your own VPP Setup
Hi, I'd like to build a VPP-prop too, but do you let the servo horn that's connected to the ball links turn around the music wire/carbon, or do you have a ball bearing between the servo arm and the music wire so the music wire turns with the motor???
Greetz, PCM
