ORIGINAL: kelldog
Would a simple flap under the belly and in between the landing gear of some of my planes work somewhat to slow a too fast of a approuch which happens sometimes. Have only 6 channel and 4 non computer radios. Sig midstar with say a 3 by 4 inch flap with holes, deflected 45 degrees or less.Would it slow her down much. I do understand there will be elevator ajustment when deployed. thanks for any imput guys!!! KELLDOG
Yup. And if you ever build a Contender, you'll note the option to build in the same sort of flap. Not much of an airbrake, but it does give you lots of lift, you can slow to a crawl. Yes, you'll have to control pitch manually, with elevator, on your non-computer radios.
Best wishes,
Dave Olson
