RE: Wildhare Ultimate Build Thread
I believe that shouldn't be a problem at all. Since the ailerons are so so responsive, You can set up the geometry to favor lots of movement on the servo and very little on the control arm. This will basically double the torque of the servo even though you lose servo speed, but since this bird doesn't need extreme throws for a fast roll rate. 3D throws are not necessary for 3D performance.
