ORIGINAL: rt3232
Pete,Dave, Mike, or any one with frist hand knowlage..
I have a "Stans" cowl and the cowl flaps are particaly open, I finaly got enough done on the fuse to put the cowl up to it, THE PROBLEM it looks like I will not get enough cooling with the flaps as set. Can they be cut and opened?? If so how?? just saw and bend, how do you suport?? I will have the dummy radial up front with the same cutout as I had on my frist build, and I only needed cowl flaps from 3 o'clock to 9 to get the cooling needed.. also what is the correct angle for fully open flaps??
Bob T
Bob,
I used the ABS plactic cowl for my 60 size Corsair and was able to cut and open the flaps using a covering iron. I do not think you can do the same with the fiberglass. You will need to open up the bottom of the cowl to vent. [&o]
Pete
