RCU Forums - View Single Post - Interferance problem/need pro opinion!
Old 10-30-2005 | 07:51 PM
mstroh3961's Avatar
mstroh3961
Default RE: Interferance problem/need pro opinion!
What engine are we dealing with? If the crystal isn't the culprit this can help to diagnose.
Check for broken insulation and shielding on the plug lead. Check the spark plug for a cracked porcelain. What were the battery voltages after the problem. Did you check the ignition switch for problems?
