RE: Enya 53-4c Knocking
Here is more info: Upon partial teardown I noticed very weak compression and a lot of blow-by from the crankcase nipple. I dissasembled the engine head and found no bent pushrods or sticking valves, sleeve looks excellent. I pulled out the front housing found the connecting rod in good shape. The timing box was removed and found no striped gears. Hope this helps for you troubleshooters.
