RCU Forums - View Single Post - control horn for pull-pull rudder
Old 10-31-2005 | 06:38 AM
RCShadow
Default RE: control horn for pull-pull rudder
The way I have solved this problem in the past is to use two of the regular control horns. Just put the second horn where the "backplate" would go and drive your screws through as usual. Now you have a setup for pull-pull.
Hope this helps.
CJ
