RCU Forums - View Single Post - control horn for pull-pull rudder
Old 10-31-2005 | 09:36 AM
carrellh's Avatar
carrellh
Default RE: control horn for pull-pull rudder
ORIGINAL: inferno6688
G'day,
Wasn't sure which forum to put this in, so here goes!
I am putting together a 40 sized plane with a pull-pull rudder set up. What are the options for the control horn on the rudder end?
Obviously i need a control horn on either side at the same spot, so the usual T style horn wouldn't really work.
Cheers.
Here's a link to a Dubro pull-pull kit
http://www2.towerhobbies.com/cgi-bin...?&I=LXEMF6&P=0
It uses a fully threaded rod through the rudder with nuts on both sides to hold it in place.
