RCU Forums - View Single Post - Interferance problem/need pro opinion!
Old 10-31-2005 | 10:00 AM
mstroh3961's Avatar
mstroh3961
Default RE: Interferance problem/need pro opinion!
Heres how I mounted the DA Ignition and battery...No glitches. Check to make sure the wire braid is intact on the plug wire and doesent chafe on any sharp edges. If you used the anderson connecter on the ignition (RED AND BLACK plug) They sometimes brake the wire where the wire is atatched to the plug. Tie that plug down so it cant flop and vibrate, or better yet remove it entirly.
ID:	346491   Click image for larger version
