RCU Forums - View Single Post - Interferance problem/need pro opinion!
Old 10-31-2005 | 11:12 AM
rctom's Avatar
rctom
Default RE: Interferance problem/need pro opinion!
I have an importand message for you. If the location of the ignition makes adifference in range checking then there is something else wrong and you need to find it and fix it.
I have had dozens of installations with all different orientations. I've had the throttle and/or choke servos as little as 3 inches from the ignition box. Never had a range or interference problem as long as everything was working properly.
Problems occurred when I had one of these problems;
ignition that had been in a crash
abraded shield on the plug wire allowing arcing from the center lead to the shield
receivers that had been through a few crashes
wrong crystal type (used a Hitec crystal in a Futaba PCM receiver)
extensions with bad connectors
bad servo feeding back interference
2 receivers interfering with each other
and a few others.
Each of these allowed the radio to work but not properly.
You need to find the underlying cause, reorienting the ignition is a bandaid when you need surgery.
TF
