RCU Forums - View Single Post - Break-in prop for .91 FX
Old 10-31-2005 | 12:16 PM
Bax
Default RE: Break-in prop for .91 FX
O.S. makes their prop recommendation based upon noise restrictions around the world. You can run a 13 x 8 prop, but you'll get a lot more noise. If you prop the engine to run with a max RPM in the high 11,000's, then you can try different props. The suggested props, though, let the engine run very quietly.
