i did not enjoy this part!
Use a fairly long block or bar while you are sanding. Look at the root and tip ribs and make sure it's about the same shape.
Fortunately this is the only piece that has to be sanded to the proper shape. The rest of the sanding is mostly just smoothing things out.
