RCU Forums - View Single Post - Onboard Glow Driver...
Old 10-31-2005 | 08:34 PM
on pipe's Avatar
on pipe
Default RE: Onboard Glow Driver...
The drivers that shut off above idle are the cats meow! If you set your carb to close
off with your throttle trim your engine should shut off with no problem. No fuel- No
run. You should have a seperate battery for the driver. A couple of higher MAH cells will do it. Will make your already reliable engine extra dependable! Ross
