RE: Tip Stalling Airplane
If you don't mind changing the appearance of the wing slightly, you can try a leading edge cuff at the outboard section of wing. A cuff would approximate a washout at the tip and could be mounted temporarily for experimentation. Look at the cuffs on the Nexstar trainer for an idea of design and mounting considerations.
Good luck!
DT56
