RCU Forums - View Single Post - H9 Arest 40
Thread: H9 Arest 40
Old 11-01-2005 | 12:26 AM
ninelaps
Default RE: H9 Arest 40
Balancing the plane upright or inverted will give you the same answer, however it may be easier to do inverted.
Work with the CG first unless you can determine the thrust line is way off the designers intent.
Look around for trim charts eg. [link=http://www.nsrca.org/trimA.htm]http://www.nsrca.org/trimA.htm[/link] and articles such as some found here[link=http://www.mini-iac.com/DesktopDefault.aspx?tabid=70]http://www.mini-iac.com/DesktopDefault.aspx?tabid=70[/link] for additional help.
