RCU Forums - View Single Post - Interferance problem/need pro opinion!
Old 11-01-2005 | 04:40 AM
rctom's Avatar
rctom
Default RE: Interferance problem/need pro opinion!
With your metal pushrods you need to have a nylon clevis insulating them from the engine. Otherwise they act as an antenna.
Beyond that it simply requires a methodical approac. Replace the receiver and retest by carefully range checking. If possible recheck using an FM receiver, PCM tends to mask problems.
TF
