RE: Cranking question
I was taught that flipping backwards also reduces the possibility of damaging an engine that might be flooded. Forcing the engine through the compression stroke in the forward direction if there is too much liquid in the cylinder can lead to bent connecting rods, cranks or worse. A flooded engine will start and run backwards. I can then get it to reverse direction or stall by dropping the throttle.
Brad
