RCU Forums - View Single Post - Ultrafly PC-9
Thread
Ultrafly PC-9
11-01-2005, 01:39 PM
32
BaldEagel
RE: Ultrafly PC-9
Adam G
I use a Jeti 18 amp with my 2212/20 which works fine, I also use Solafilm light to cover the foam as it adhears at 80 deg and so does not melt the foam underneath, see pic attached its the red and white one not the feathered one. one thing you have to be carful of is the canopy detaching in flight with the speed it will fly at with the AXI if you look at the pic you will see a piano wire pin at the rear, I expoxied a snake inner through the canopy into the rear and push the pin through to hold the canopy on much more secure than the magnet.
Reply
Like
BaldEagel
View Public Profile
Send a private message to BaldEagel
Find More Posts by BaldEagel
View iTrader Profile
