I can't believe how light the Saito 72 is! Shouldn't be much weight gain at all considering I had a honkin tuned pipe on there!
But the raw 4 stroke power will be awesome!
Do you actually fly all the time with max throws or is that your high rate??
How much spoilerons do you use? How do you set them up? You mix them with the elevator or use the knob? I can't wait till I get that 9ZAWC2! Will make my life easier! After I figure out how to program the darn thing!
Thanks!
chris
