Originally posted by Chris 540
Do you actually fly all the time with max throws or is that your high rate??
How much spoilerons do you use? How do you set them up? You mix them with the elevator or use the knob?
Thanks!
chris
Chris,
My high rate is ridiculous on the throws and the low rate is just slightly less ridiculous. The only way its flyable that way is I have tons of Expo set on all surfaces. With all that expo, if you use a light touch your not into the max deflection but when you need it its right there.
I'll have to look at the radio to see how much "flapperons" I use. I have it mixed with elevator and set on a switch so they dont have be active all the time. On the T6XAS its called "2-6 mixing."
