RE: Ultrafly PC-9
Bald Eagel,
Found the AXI 2212/20 and see there is a radial mount kit available. Is this the way it mounts to the PC-9? I am also assuming by the picture of the motor that the prop mounts on directly to the motor shaft using the avilable adapter, no gear box needed, is this correct? Anything else I need to order to be able to install this motor? Thanks a lot for your help, never done a brushless conversion.
