RCU Forums - View Single Post - GSP Giles 202
Old 11-01-2005 | 05:09 PM
  #52
jho
Default RE: GSP Giles 202
Hi Pete,
I called the dealer the other day and told him about the building flaw in my kit. He said this would be rather “normal allowance” in production and should neither harm the stability of the wing tube nor the flying performance. He however advised me to contact the importer Jamara which I didn’t. I was a bit tired of argueing with him.
In the end I loosened the outer tube from the fuselage, widened one of the holes in the fuselage a bit moved the tube a little backwards and the wing fit perfectly.
I will power mine with a Webra 120 with pump on a 16x8 apc prop. Let’s see how this turn’s out to be.
