RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 11-02-2005 | 01:13 AM
  #1366
rcfury's Avatar
rcfury
Default RE: Vectorflight Edge 540 build
Bunman: Well for the Elevator my low rates are just a hare above 3/8" and high rates just above 5/8"... Rudder im using 1 1/2" for low rates and as much as I can squeeze for high rates...
Well im almost done with everything now, Im still waiting for my my onboard glow to arrive from Horizon. And need to hit the hardware store and find a pipe holder or something to secure the flexpipe. Everything should work out fine. If you can in one of the pictures i decided to use one of my extra revolution base loaded antennas instead of the whip.
Question though. Granted the fuel lines are a tad long but, would it be a problem for having the lines set up like that? Exiting the top of the firewall then all the way down. Worst case scenaro i have an extra shaker pump thats collecting dust.
ID:	347462   Click image for larger version
ID:	347463   Click image for larger version
ID:	347464   Click image for larger version
ID:	347465   Click image for larger version
