RE: Reflex problem
The registration process is fairly automatic. It fails if you enter a misspelled email adress or if you are using a spam filter that blocks the emails. I heard about an AOL user who was unable to register because AOL was blocking the email confirming the login. But all this happens outside the reflex homepage and there is nothing these guys could help. Pls check your email adress. Is it longer than 32 characters? In that case, the system may cut some essentials.
