Installing Servo's - Help & Advice needed :)
dbows right ya should have a throttle trim ya can adjust,futabas are inexpensive but not cheap,they are good radios,does the car stop when you move the trigger? try moveing the trigger if the car stops ya need to adjust the trim knob on it,if the front tires move when ya pull the trigger ya have yer servo channels reversed,swap em an start over
