How you will know the impact is to fly the plane at your normal speed and adjust your low rate elevator so that you can hold full elevator deflection and have it loop and not snap. Then as you change CG, you can quantitatively measure and understand the impact. That is what I do and it works great.
ORIGINAL: Hammbone
Well, I'll try moving the CG back some and see if that helps.
Thanks, Jim
