RE: Enya 53-4c Knocking
Did anybodyy consider that his fuel source is the cause for the engine leaning out and detonating? Could it be that he is getting a lean operation during take off. All the other arguments aside, it seems the engine is leaning out after setting the needle valves to the desired point of operation. That means either a piece of debris is in the way (causing a restriction) or the fuel source is off somewhat.
Cheers,
Chip
