ORIGINAL: RCIGN1
Hey RTK...Can we borrow your 110X for a test in one of our Formula 1 Kelly airplanes?
200 mph is a distinct possibility
You can borrow it any time you like. I would just appreciate that it does not contact the ground nose first.
At least not at 200mph
ORIGINAL: Modified
How many RPM should a new BME 110 turn with a BME 28/10 prop? It only has about 20 min run time and is turning 7200 RPM static. Also what temp should it run at and what would be the max? Thanks
Those #'s don't sound unreasonable to me. Just don't be running it for more than a few seconds and the ground at WOT or soon you will find those #'s dropping drastically.
Don't worry about the temps, as long as you have it baffled well and slightly rich on the top end you will be fine. Don't do a lot of ground run ups, sometimes the air flow is not what we think it is.
ORIGINAL: Silversurfer
We'll try one on RTK's 110 when he brings it out.
Now if the 110 turned that kind of rpm with an MSC 28-10 I would be either pretty darn skeptical or absolutely amazed!
Yes Pat we will have to see some time, we might both be amazed
