To sum up ...
N.A setup
1 - aileron
2 - elevator
3 - throttle
4 - tail/rudder
5 - unused /gyro settings
6 - collective
Battery -> two wire side of esc
Three wire side of esc -> Motor
servo connection from esc -> ch# 3 on the receiver
The existing battery plug and motor connection from the receiver and be taped to the receiver as they will no longer be used. All the other servo's are left as is. This is assuming you are using the walkera receiver. If not, there won't be extra plugs
If by moving the main props left and right you mean the aileron/elevator functions are not working then you may not have the servo plug connected right ways around to the receiver as thecheatscalc suggested. Check the wire colors against the existing servo connections to the receiver to ensure the proper orientation. Signal = yellow/white, + power = red/orange, ground = black/brown generally. If this doesn't fix the problem, proceed to the next item.
If the motor won't spin up at all there is a good chance the esc is not seeing 0 throttle. You made need to adjust the throttle trim downwards to enable it to spin up. If that doesn't help you could also try reversing the throttle channel (after securing the heli and being ready to unplug the battery if things go awry).
