RE: easy 1.08 question
The engine does have a gasket from the factory. It fits very closely in the groove that the top of the liner goes into. You need the very sharp tip of a#11 blade to work the gasket out.
If you added the gasket that came in the gasket set without removing the old one, then your engine will be undercompressed for regular fuels. You'll likely have running problems.
