RE: BYRON AT-6...Building Tips and Tricks
Yes make sure you have the three piece flaps. We mounted the motor directly to a flat firewall that was bolted to the outer ring of the fuse backed up by a 1/4 inch plywood ring. Then tied it into the next former back with longerons and bolts.
