RCU Forums - View Single Post - Does anyone know of a source for a precut firewall?
Old 11-02-2005 | 03:25 PM
FantzyPantz
Default RE: Does anyone know of a source for a precut firewall?
ORIGINAL: Villa
I have always felt that if you cut the POLY firewall with a shoulder (rabit?) that not enough material is left for the screws holding the firewall to the PVC. If you put in a plain POLY firewall and then cutout four POLY right angle triangles with two equal sides about 1 inch, they can be located at the corners of the firewall so they overlap the PVC and thus serve as a shoulder at the corners. One screw in each should do it. Might work fine with just two triangles in diagonally opposite corners. Comments?
Sounds like a good idea, I generally cut 2 pieces of POLY, 1 that fits inside the gutter pipe, and the other slightly larger, then GOOP them together for the motor mount.
By the way, Villa - I would like some details on the Canard plane that is featured on your Avatar...
