RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 11-02-2005 | 03:31 PM
  #3657
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hi All... Well I re-maidianed my "Do".... It was ok I guess... Got in about
6 flts... Man the 100 pushes some air on the 46, It would hover at ease
at about 1/8 throttle or less.. It floated/landed about the same as with the
YS 63 I did not notice any difference... I could not invert flat spin worth a
darn it kept outside looping out... Even with low rates.. I also noticed I
needed a bit of push while inverted. Guess I'll play with the C.G.. But
once/if I get that worked out, I think a rising spin will be easy:-) One
thing is for sure with the S-100 and 16x4W... The Wing Sings...
Ohh, fuel consumption seemed to be about the same time wise... Most
the time the stick was near idle... Ohh and I have the 10oz tk. now..
dougwill & The MacDaddy I use to use mixes for knife edges, I think I
had about 4-5% on the rudder(master) to elevator(slave)... And I think
the same % on the rudder(M) to aileron(S) But I have since stop using
the mix and just work the sticks...
crank Not much test flt. (6) on the "Do" with the S-100 16x4W APC, But
my low end responds was good as far as I could tell, but you do have to
get use to "Just" touching the stick...... Or it's too much...
