ORIGINAL: afox989
Can I convert the blade to mode 1? (throttle on the left)
You can buy the E-sky Tx on mode 1...may be on 35mhz though....Theoretically it should be possible to convert if you are good with that sort of thing....Maybe the E-sky Tx hardware transplanted into the blade tx or vice versa.....good luck!!
