RE: Looking for an ARF with flaps
Flaperons on a standard wing plane may or may not change the pitch. They increase drag, lower stall speed and provide lift. You can mix in down elevator if pitching up is a problem. On the delta wing Stryker, the elevons are rearward and can't help but control the pitch of the plane.
