RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 11-03-2005 | 12:10 AM
  #1369
rcfury's Avatar
rcfury
Default RE: Vectorflight Edge 540 build
Gjeffers: Thanks for the heads up. Well i got my tank as low as i can get it so it should be allright. Then again my eyes have decieved me before. Pretty much i just got to burn some fuel and see how it works. Im kinda a nit picker and nothing could be perfect. Well im new to running motors inverted so bear with newbieness...
Anyway everything is pretty much done put the decals on the cowl and secured. I do need to drill a hole in the cowl so I can access the low speed needle, but thats it. Gosh i can tell you one thing since i mounted the motor inverted its so much easier to take the cowl on and off. It just slides on and slides off, with no hesitation. So awsome!!! Tomorrow im going to balance and weigh the plane. Hopefully i didn't gain to much weight before the build.
