RCU Forums - View Single Post - Can anyone explain INCIDENCE to me?
Old 11-03-2005 | 02:57 PM
britbrat
Default RE: Can anyone explain INCIDENCE to me?
You are more-or-less correct, but it is easier to shim the trailing edge up, rather than try to lower the leading edge.
Try reflexing the ailerons first. If that doesn't work, the problem may not be an incidence issue.
Get back to us with the results from the aileron changes, before you try anything else.
