RE: Great Planes Tiporare ā Thirteen Year Build
Received my new APC props. After my mishap with the prop coming off I decided to place an emery cloth washer between the engine thrust drive face and the spinner back plate to reduce slippage between the two parts. Iām using 3M medium grit MR4 emery cloth with the grit side facing the spinner back plate. I tightened the prop nut very tightly and hopefully the problem is solved.
Everything is ready to go for the first flight this weekend!
