RCU Forums - View Single Post - os 46 needle setting problem
Old 11-04-2005 | 11:03 AM
Bax
Default RE: os 46 needle setting problem
Doesn't sound like anything's wrong. 2-1/2 turns out from closed would normally be a very rich setting. To tune the engine, you'd turn the needle clockwise to lean it towards peak. Turning the other way will richen...but many times, the inlet of the engine prevents going rich beyond a point. If the needle falls out, we'd expect the engine to lean and die.
